swift's avatar
swift
11 years ago
T V guide for Tucson
For months now I've been trying to get TV listings for Tucson, but my only choice seems to be Phx. Before that there was a huge list of areas but very confusing. I sign in to Tucson zip code, why don't I automatically go to Tucson listings? Am I doing something wrong?
  • swift,
    I agree that something appears to be up with the site. I found that if you change the location at the top right of the page to Phoenix that the listings match Tucson's channel lineup. It looks like the 2 area's might be reversed on the site. Let me know if t works the same for you so I can get it reported accurately.
    bryaninphx,
    If you can try it too and report back your results I'd appreciate it.
  • bryaninphx's avatar
    bryaninphx
    Valued Contributor
    I cannot find it by city or Zip Code either.
    If you sign in with your cox email address and password, do the correct listings for Tucson come up?
  • swift's avatar
    swift
    NO, I've tried all different zip codes and signing in & out, no difference.
  • swift,
    bryaninphx,
  • swift's avatar
    swift
    You are absolutely right! Choosing Phx on the upper right brings up a whole new list of options.  You are on Phx area but looking at Tucson channels, plus on the left side you can actually choose Tucson. Thanks for the help! I can't believe no one has complained about this.
  • swift,
    Thank you for confirming my findings. I've reported this and hope to find it corrected soon. I'll update you when I know more.
    Have a great day!
