Orange County, CA - TNT went from channel 1018 to 1003?
Seeing that TNT went from being channel 18 (SD) and 1018 (HD) to 3 (SD) and 1003 (HD). When checking https://www.cox.com/residential/tv/channel-lineup.html and searching for TNT it shows 3 and 1018 still....seems strange that there is a difference between the SD and HD channels....and that the channel guide online is wrong. Which is right?
If TNT *IS* supposed to be 1018, how does that get reported?
  • Hi @Mvalpreda,
    I can understand how this change has caused some confusion for you. As of 2/17/21 TNT has moved to channel 3 from 18. All of the channels are HD, so you can use channel 1003 or channel 3. Either one will work. I hope this clears things up for you.
    Ben S.
