- CurtBHonored Contributor
See if this helps. www.cox.com/.../using-contour-2-voice-guidance.html
- CesonnierNew Contributor
Yes, I made sure the video description was off. I even used the voice command to make sure it was off. The closed caption is off too. Just started with a show from last night and tonight's shows, all NBC.?
Try turning the SAP audio setting off. If it's already off, try cycling it on then off again.
- 2 months ago
- 2 years ago
- 3 months ago
