dmorack's avatar
dmorack
13 years ago
NHL Center Ice HD
Is there any reason why the NHL Center Ice HD channels don't work (black screen) in Fairfax County?  I thought the first 2 weeks were free.  Interestingly enough, I am able to watch NBA League Pass which I never ordered.  Did Cox mix up the channels?
I'd order NHL Center Ice of Cox can guarantee the HD channels will work.  I have the Whole Home DVR and have reset the box 3 times.  All of my other HD channels work fine.
-Doug
  • ChrisL's avatar
    ChrisL
    Some games are available in HD but not all however.
  • dmorack's avatar
    dmorack
    I understand that.  The guide shows that 4 games were available in HD last night around 8pm.  I got to see the first 30 minutes of one game (7-7:30pm).  Then, the screen froze and none of the NHL Center Ice HD channels were viewable after that.  Since all of the other HD channels worked, including NBA League Pass which I have not subscribed, doesn't that seem to indicate a problem with the NHL Center Ice HD package?
    If I tune to the SD channel, the bar at the bottom also states I can press "A" to watch in HD.
  • ChrisL's avatar
    ChrisL
    The sequence of events you described sounds more like a technical issue than anything.  When I look from this end the set top box isn't responding to diagnostic requests suggesting a signal or equipment related problem.
  • dmorack's avatar
    dmorack
    The last tech that visited here about a month ago put on a new filter on the back.
    So you are saying I need to have another service call?  I've had more services calls over the past year than over the other 13+ years I've lived here.  Every cable leading to the cable box has been replaced.
    The same issue is occurring this evening.  I am able to receive the NBA League Pass HD channels, but not the NHL Center Ice HD channels.  Is NBA League Pass free?
  • dmorack's avatar
    dmorack
    NHL Center Ice HD worked fine until, as I suspected, NBA League Pass started right at 6pm.  I can watch the NBA games in HD which I don't pay for, but I cannot watch the 2 week free preview of NHL Center Ice HD.
    -Doug
