- bryaninphxValued Contributor
TiVo is the only Stand-alone Retail CableCARD DVR that is still supported.
- TiVo DVR (standalone device) Multi-Room option with the TiVo Mini - Includes Cox OnDemand support
TiVos new pricing includes the 1st year of service, and is $150/year after the first year
- TiVo Bolt 4-Tuner (500GB or 1TB)
- TiVo Roamio Pro 6-Tuner 3TB
Your other option is a PC based CableCARD tuner
- SiliconDust HD HomeRun Prime (Windows 7 or 8.1 Pro PC required for use with this device for Copy protected channels)
- Ceton InfiniTV (Windows 7 or 8.1 Pro PC required for use with this device for Copy protected channels)
- Hauppauge WinTV-DCR-2650 (Windows 7 or 8.1 Pro PC required for use with this device for Copy protected channels)
You should also keep your eye on the HDHomeRun DVR Software it is still in testing, and currently does not support Copy protected channels.
- Tesseract257New Contributor
I was looking into the Motorola DCX3400 HD / DVR Set Top Cable Box which the specs indicate is cable card ready, will this
DVR be unable to operate on the new all digital network?
- DominoValued Contributor III
A) You can't purchase that DVR for use on a Cox system. B) Motorola DVRs work on only some Cox systems.
- wees41Contributor II
You can't purchase the Motorola boxes no one sells them nor will Cox authorize it for the network.
wees41 said:
You can purchase the Motorola boxes....
Where?
it was a typo I meant can't purchase
You could buy a used / refurbished Motorola DCX3400 HD/DVR on eBay and there are other sellers, on the internet, but it would be a doorstop.
The problem is they were never intended to be sold at retail, to an end user, and Cox would not Authorize the box for use. The software and guide the box runs on is proprietary to the Cable Co, and Cox has to pay a licensing fee for each DVR/STB.
There are websites claiming 100% Guaranteed money back success, if your are up for the challenge, let us know how it goes.
