HalvinCobbes's avatar
HalvinCobbes
13 years ago
Internet connection dropping frequently for short durations.
Several times a day I will lose internet for anywhere from seconds to minutes.  I'm trying to use the net for gaming and other real time applications and it becomes impossible.
My modem is a Motorola SB6121.  I just had another disconnect and immediately checked the modem logs.  Here is the log entry for the exact time of disconnection:
Jul 31 2012 | 3-Critical | T05.0 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=cc:7d:37:1a:51:8c;CMTS-MAC=00:19:2f:e5:d5:8b;CM-QOS=1.1;CM-VER=3.0;
How can I fix this problem?  It is getting to be a major headache.
Thank you.
