FujiwaraTakumi's avatar
FujiwaraTakumi
10 years ago
Packet loss and poor speeds
Hi there, I've been going back and forth with Tier 1 over the phone, but the most I've been able to get out of them was a power cycle and eventually scheduling a tech to come out and look at the issue. I've been seeing some other folks with similar problems posting, so I figured I would get my case posted up as well.
In short, there are two main issues that I'm trying to get a handle on, the most annoying being the packet loss I'm experiencing. I've been running tests a few different ways, using a third party in a geographically separate location (I'm in San Diego, he is in Las Vegas) with a different ISP as a control.
Here is a screenshot of 5 second snapshots running iperf: http://i.imgur.com/pnd46vP.png
Here's a tracert to that server: https://i.imgur.com/Fc5jLeJ.png
My "control" lost a total of 3 packets over the same 5 minute period. We also repeated the test using a server of his located in a different data center with similar results.
Here are PingPlotter results for a trace to Google over a 60 second period: https://i.imgur.com/cXiyMfT.pngT
This is a separate PingPlotter log for a trace to Google over a 5 minute period: https://i.imgur.com/qDVhPvC.png
The tracert to Google: https://i.imgur.com/2PiKvcs.png
In the process of trying to solve the issue, I've run all of the same tests with and without a router, with no change in the results. And I've purchased a new modem (which needed to happen anyways, due to the last modem only having 4 downstream bands).
The other issue I've been experiencing is fairly low download and upload rates. I'm on the 300/30 plan, but am only averaging 190/1.2 (yes 1.2mbps) in speed tests.
Worth mentioning that within my modem's logs, there are quite a few Critical entries; however, I'm unfortunately not familiar enough with this part of the network stack to know what they mean.
Modem logs are here: https://i.imgur.com/aMs4zG0.png
As mentioned earlier, there IS a tech coming out in a couple of days to take a look at things, but any guidance in the meantime would be appreciated.
  • Alright, so the tech showed up and says there is a ton of inconsistency in the signal coming from the tap, so he put a ticket in with maintenance to come resolve whatever that issue is. Fingers crossed that this solves the problem. I suppose the other location I was testing from having the same issues that were resolved a couple of days ago was just an odd coincidence.
    Gonna leave this open just in case the fixes they apply next week don't solve the problem, but will update as soon as I know one way or another.
