JonathanJ
5 years agoFormer Moderator
@Peppy22
I apologize for any inconvenience this has caused. Does this also happen on channel 1008?
Cox Moderator
Cox Moderator
- Peppy225 years agoNew Contributor II
Yes. Also on channel 1008. The video lags the sound. Again, this only occurs with the local channel during live telecasts. Commercials are not affected. And again, I can use the delay feature on the TV but it is already at the minimum setting and adjusting it only exacerbates the problem. Additionally, if I was able to adjust it, then I'd have the opposite issue on channel 8 during all NON LIVE broadcasts and on ALL of the other channels all of the time.
