If you're only missing a few channels, it may be due to a newer (higher) compression scheme. When you first lost the channels, the tech probably moved your service to an older head end still supporting the older compression.
Did the tech happen to mention a new compression scheme? If so, did the tech mention if your TiVo and card support the new scheme(s)?
I don't know the new scheme(s) but I suspect MPEG4. A mod would need to provide any newer schemes and you'd have to verify if your equipment supports it/them.
you mean mpeg 4 tivo's support mpeg 4
Do I mean what?
Which component decodes: TiVo or the cablecard? I don't know much about cablecards. I remember reading about 'em years ago...and thought it was pretty cool (cheaper TV)...but I never opted to get the tech. If TiVo supports MP4, then it's a question for the card.
- Andrew_Wees6 years agoContributor III
the tivo handles video the cablecard handles encryption
