If you're only missing a few channels, it may be due to a newer (higher) compression scheme. When you first lost the channels, the tech probably moved your service to an older head end still supporting the older compression.
Did the tech happen to mention a new compression scheme? If so, did the tech mention if your TiVo and card support the new scheme(s)?
I don't know the new scheme(s) but I suspect MPEG4. A mod would need to provide any newer schemes and you'd have to verify if your equipment supports it/them.
- Andrew_Wees6 years agoContributor III
you mean mpeg 4 tivo's support mpeg 4
Do I mean what?
Which component decodes: TiVo or the cablecard? I don't know much about cablecards. I remember reading about 'em years ago...and thought it was pretty cool (cheaper TV)...but I never opted to get the tech. If TiVo supports MP4, then it's a question for the card.
the tivo handles video the cablecard handles encryption
- Remark6 years agoNew Contributor
This also happened starting late last July, so I doubt the data format has changed twice in the past 6 months with exactly the same results. Something more elemental is different. Like I noted, it was nothing the local techs could update, replace, initialize, power-cycle, refresh, reset, or reboot, that made this problem go away.
I'd bet something about supporting newer Coutour boxes and legacy devices with differing protocols over the same connections, then something was changed or dropped w/o warning ... like some network equipment rev/patch.
Just guessing.
- ColleenD6 years agoModerator
Remark, are you getting a message that you aren't authorized to view the channels, or is there a different message displayed? I was able to identify your account and have found that the issue we visited you for in November was related to an outage. Once the outage was cleared the service would have started working again. I have sent some updates to your cable card and adapter in the hopes it will resolve the trouble you're having, but if it doesn't I may need you to email us at cox.help@cox.com so we can have a timely conversation and authenticate, etc.
Bruce, tech's can't move equipment the way you're describing. Moving equipment to a different head-end would cause the equipment to cease functioning altogether.-Colleen
Support Forums Moderator- Bruce6 years agoHonored Contributor III
Yeah, pointing to a different head end was just a [bad] guess because it appeared the tech coordinated something to be reconfigured. Perhaps the tech just expedited correcting the effects of the since-fixed outage.
What updates did you send to the cablecard?
