linda_scury
4 years agoNew Contributor
I have an RX 11RF. About a week ago I urned in my old one becasue it would not change channels. The first one would lock up when I selected Bose off the menu and it locked up. I went throught Customer Support and we did the same things without it working. I got a second rmore and had the same results. the store did not have the newer one I use on the other TV. Now channel selection is very slow and it takes awhile to load Cox sometimes. As of this morning Cox will not load on the primary TV. Its very frustrating
4 years agoHonored Contributor III
1 box, 3 remotes and same problem. You may have a faulty box.
You can try some documented procedures, such as factory reset, un-pair, re-pair, etc.
Look for Troubleshoot Remote Issues.
