- Hiphubby123New Contributor III
Well, the light just came back on. Strange how it turned off and then turned back on. The recording was not affected. Problem fixed.
- BenS1Former ModeratorHi @Hiphubby123
I know how important it is to make sure that your recordings are running as scheduled. Sometimes the red light will be on a little longer after a recording has finished or be delayed when a recording starts. As long as your recordings are found and you are able to access them with no issues, everything is fine.
Ben S.
Cox Support Forums Moderator - bearone2Contributor III
if the light's not on, it's not recording.
delete some recordings!!
