FWB_customer
8 years agoNew Contributor
I've noticed that if a show is not tagged or designated "Repeat" on the guide, the DVR schedules it to record the episode, but in my case it schedules an entire day of episodes (has been the case with Chicago PD and now an entire lineup of Whose Line is it Anyway on channel 1368 UPHD in Ft Walton Beach, FL - 26 episodes starting at 7:59 on Monday 30 April straight through to 2:00 am on 1 May). When I press info on these scheduled episodes, it does not say "New" or "Repeat." I have set my DVR to record New episodes only, which it does. Now it appears that if the episode is not tagged as a Repeat, the DVR tries to record it like it does a new episode.
MariaL
8 years agoModerator
Hi FWB customer,
Since the broadcast of Chicago PD and Whose Line Is It Anyway are in syndication, in order to record the current episodes, you will need to record the series from the guide. For example, the newest episodes for Chicago PD will air on NBC on May 2nd. From the guide, you will select the show, select Record and then All Episodes. The Record options will reflect Record – New Episodes Only and Channels – NBC Network for your area. Currently, your series recording for Chicago PD the channel will reflect HD Only. You would follow the same steps for Whose Line Is It Anyway.
Maria L.
