rcaron
6 years agoNew Contributor II
I did that test and unplugged the Ethernet cable too. Held for 30 seconds, turned tv back on, plugged in Ethernet and it recognized the cable. I’m going to turn it off and on now again.
rcaron
The Ethernet connection is holding in store mode after the cold reboot. Thank you so much! You’ve made my day!
Does the wired connection hold in Home Mode?
- rcaron6 years agoNew Contributor II
I can switch it back to find out, I haven’t try yet. Will do now.
i left for house and tv for 90 mins and just turned the tv on and there’s no connection on the store mode. Now it doesn’t work in either mode. I don’t understand why if it makes the connection why it loses the connection when the tv is turned off and back on
