I don't think the Cox Contour mini-box is capable of volume control on its own.
I'm trying to get this to work with a very weird setup.
Cox doesn't play well with weird setups.
I'll have to stick to turning the volume control knob manually on my Logitech speakers.
It's like the 50's again!
You could upgrade to a remote controlled speaker system. Sound bars are pretty cheap if you have room on the desk. Anything that uses IR would probably be compatible with the Cox remote. I know you probably didn't want to throw money at the problem, but something to consider.
