fanderson4
5 years agoNew Contributor
I just upgraded cable box to the new contour 2 and cant pair my bose soundbar with Samsung tv. When i first set it up, it worked ,but now everytime I try to pair using the remote none of the codes work. Do I need to restart or refresh the cable box
Your soundbar and TV should be already paired because you didn't change this connection, right? You had only swapped the cable-box.
What's the problem...no audio?
