mare70's avatar
mare70
8/29/2019, nbc and msnbc breaks up and sound break down.
In south Windsor our nbc and msnbc and sound breaks down.
  • Same here in Southington. Thought it was my equipment but it appears to be limited to certain channels.
    • CrystalS's avatar
      CrystalS
      Hello. This sounds frustrating. What channels are you experiencing the issue on? Where are you trying to watch these channels?
      Crystal
  • JonathanJ's avatar
    JonathanJ
    @Mare70
    If you're still having an issue please try rebooting the cable box and see if that helps. If still having an issue after please email your full-service address and name to cox.help@cox.com.
    Cox Moderator
    • HDTV_Guy's avatar
      HDTV_Guy
      Contributor
      I dont use a cable box...cablecard only. For some reason with no action by me, its been clear for the past few days. Can a root cause be determined and communicated to the community? This may help future issues.
      • Allan's avatar
        Allan
        Hello HDTV_Guy. Since you are using a cable card, I recommend rebooting the tuning adapter. Please let us know if there is any change. Thanks. -Allan Cox Support Forums Moderator.
