laseron's avatar
laseron
Will a NetGear AC1200 range extender work with my Cox Panoramic wifi?
Trying to get a Netgear range extender to work with Cox Panoramic wifi. Will it only work with the Pod?
  • JIMMYSAB's avatar
    JIMMYSAB
    It should work just following the set up steps from Netgear. That said, I’d recommend an access point instead. It would mean running Ethernet cable from your Cox Panoramic gateway/modem/router to a location in the house where you want connectivity. Worth researching if you haven’t already considered it. The biggest benefit is speed. With the AC1200, you’ll drop to half of what you get now on WiFi. So while you may get a signal to the area you need it may be too slow for what you intend to connect (eg. Gaming device or media steaming).
