Try replacing your ethernet cable with a cat 6E , and verify in your settings the connection speed of your ethernet connection. (Ensure you are plugged into the RED port on the PW8, (port 4)).
- HumbleGuyGaming9 months agoNew Contributor
im using cat 6E and in the correct port
- Darkatt9 months agoHonored Contributor
Have you verified your settings for the network? I have an Alienware R16 with a 2.5gbps Killer ethernet port, and the default setting was for 1gbps. I had to manually change the settings. ALSO, my original ethernet cable a Cat 6E was bad, replacing it and fixing the settings were BOTH required for me to get 2.5 gbps speed from my ethernet.
Go into network and internet/ethernet can verify the link speed. I am currently on 500 down/50 up, but yes my equipment can handle MUCH faster. Even though -
I verified my network card in my PC it's a 2.5 GbE internet card. My download isn't the issue. My upload is speedtest shows it's 40 mbps for me. But whenever I'm sending a constant stream for twitch why wouldn't my upload be that. It's why I used OBS provided twitch bandwidth program. It takes the servers they specifically use for hosting and allows me to see what my upload is for streaming.
