DBX
4 years agoNew Contributor
SB8200 - Dynamic Range Window violation- RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Anyone have any advice? Tier 1 says, call Arris, it isn't us... I'm experiencing after an outage in our area a couple weeks ago, speeds less than half of normal, and repeated packet loss and log entries;
04/14/2020 20:06 | 2436694061 | 5 | "Dynamic Range Window violation" |
04/14/2020 20:06 | 82001200 | 5 | "RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=18:9c:27:fb:66:d5;CMTS-MAC=00:b6:70:98:62:41;CM-QOS=1.1;CM-VER=3.1;" |
04/14/2020 20:06 | 67061600 | 6 | "DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=18:9c:27:fb:66:d5;CMTS-MAC=00:b6:70:98:62:41;CM-QOS=1.1;CM-VER=3.1;" |
Channel ID | Lock Status | Modulation | Frequency | Power | SNR/MER | Corrected | Uncorrectables |
22 | Locked | QAM256 | 909000000 Hz | 8.5 dBmV | 39.9 dB | 0 | 0 |
1 | Locked | QAM256 | 783000000 Hz | 10.9 dBmV | 41.1 dB | 0 | 0 |
2 | Locked | QAM256 | 789000000 Hz | 10.8 dBmV | 40.8 dB | 0 | 0 |
3 | Locked | QAM256 | 795000000 Hz | 10.7 dBmV | 40.9 dB | 0 | 0 |
4 | Locked | QAM256 | 801000000 Hz | 10.6 dBmV | 40.9 dB | 0 | 0 |
9 | Locked | QAM256 | 831000000 Hz | 10.1 dBmV | 40.8 dB | 0 | 0 |
10 | Locked | QAM256 | 837000000 Hz | 10.0 dBmV | 40.7 dB | 0 | 0 |
11 | Locked | QAM256 | 843000000 Hz | 9.8 dBmV | 40.5 dB | 0 | 0 |
12 | Locked | QAM256 | 849000000 Hz | 9.7 dBmV | 40.6 dB | 0 | 0 |
17 | Locked | QAM256 | 879000000 Hz | 9.0 dBmV | 40.3 dB | 0 | 0 |
18 | Locked | QAM256 | 885000000 Hz | 8.8 dBmV | 40.1 dB | 0 | 0 |
19 | Locked | QAM256 | 891000000 Hz | 8.6 dBmV | 40.0 dB | 0 | 0 |
20 | Locked | QAM256 | 897000000 Hz | 8.5 dBmV | 39.8 dB | 0 | 0 |
21 | Locked | QAM256 | 903000000 Hz | 8.5 dBmV | 39.9 dB | 0 | 0 |
25 | Locked | QAM256 | 927000000 Hz | 8.8 dBmV | 39.9 dB | 0 | 0 |
26 | Locked | QAM256 | 933000000 Hz | 8.8 dBmV | 39.8 dB | 0 | 0 |
27 | Locked | QAM256 | 939000000 Hz | 8.8 dBmV | 39.9 dB | 0 | 0 |
28 | Locked | QAM256 | 945000000 Hz | 8.9 dBmV | 39.9 dB | 0 | 0 |
29 | Locked | QAM256 | 951000000 Hz | 8.9 dBmV | 40.0 dB | 0 | 0 |
30 | Locked | QAM256 | 957000000 Hz | 9.1 dBmV | 39.9 dB | 0 | 0 |
33 | Locked | QAM256 | 357000000 Hz | 9.6 dBmV | 41.2 dB | 0 | 0 |
34 | Locked | QAM256 | 363000000 Hz | 10.0 dBmV | 41.5 dB | 0 | 0 |
35 | Locked | QAM256 | 369000000 Hz | 9.9 dBmV | 41.4 dB | 0 | 0 |
36 | Locked | QAM256 | 375000000 Hz | 10.2 dBmV | 41.6 dB | 0 | 0 |
37 | Locked | QAM256 | 381000000 Hz | 10.3 dBmV | 41.5 dB | 0 | 0 |
38 | Locked | QAM256 | 387000000 Hz | 10.3 dBmV | 41.6 dB | 0 | 0 |
41 | Locked | QAM256 | 405000000 Hz | 10.7 dBmV | 41.6 dB | 0 | 0 |
42 | Locked | QAM256 | 411000000 Hz | 10.7 dBmV | 41.4 dB | 0 | 0 |
43 | Locked | QAM256 | 417000000 Hz | 10.7 dBmV | 41.6 dB | 0 | 0 |
44 | Locked | QAM256 | 423000000 Hz | 10.8 dBmV | 41.6 dB | 0 | 0 |
45 | Locked | QAM256 | 429000000 Hz | 10.8 dBmV | 41.5 dB | 0 | 0 |
46 | Locked | QAM256 | 435000000 Hz | 10.9 dBmV | 41.6 dB | 0 | 0 |
159 | Locked | Other | 300000000 Hz | 12.4 dBmV | 42.2 dB | 149830240 | 0 |
Channel | Channel ID | Lock Status | US Channel Type | Frequency | Width | Power |
1 | 1 | Locked | SC-QAM Upstream | 19300000 Hz | 6400000 Hz | 34.0 dBmV |
2 | 2 | Locked | SC-QAM Upstream | 25800000 Hz | 6400000 Hz | 35.0 dBmV |
3 | 3 | Locked | SC-QAM Upstream | 32200000 Hz | 6400000 Hz | 35.0 dBmV |
4 | 4 | Locked | SC-QAM Upstream | 38600000 Hz | 6400000 Hz | 35.0 dBmV |
