fiber speeds & now no fiber, not a cox issue.
i'm not sure how or what is expected from the tech in supporting non cox equipment!
It has nothing to do with the equipment. I also never said that the loss of fiber speed was their issue. If you read my post, you would see my issue is the complete loss of upload speed. If I read around on this forum a little bit, I see many people saying the same thing. Please don't reply if you aren't going to be helpful.
- bearone26 years agoContributor III[deleted]
- Enigmau56 years agoNew Contributor II
Your reading comprehension skills could use some work. From what I've seen, you hop from thread to thread telling people the issue is with their equipment (in what appears to be an attempt to troll). This is a support forum, not 4chan. Go away.
As an update to this thread, after having a tech come out today: the issue was found to be with external wiring and they are sending someone in the next 48 hours to fix it. Imagine that, it had nothing to do with my equipment (exactly like i thought).
not at all, be interesting to see if you report back if speeds are the same as before moving.
