Does the Orbi app perform a speed test from the iPhone or does it perform a speed test from the router?
If your Negear is working, it's already provisioned. Your modem is on the list of Cox certified modems. Upstream is fine, right? You only need 4 for 35 Mbps.
- Robert_M_6 years agoNew Contributor II
I was using Orbi iPhone App to perform the test. Upstream is fine..
I did a factory reset on Modem and was back to around 300-350mb on the Cox Test on their website. Then it dropped to around 220mb after about an hour
