WiderMouthOpen
2 years agoEsteemed Contributor III
Try Pingplotter to plot your latency issues over time. This will also show which hop the latency is occuring. If first hop, the issue is between your computer and router. If second hop it is between your modem and Cox. WinMTR can also show simular data and is open source but not as user friendly as PIngPlotter IMO. Either way, set the target to either the game server you are playing on or if unknown, 8.8.8.8. To share the data go to File > Share > Create Share page.
