chi2phx's avatar
chi2phx
Contour HD picture quality
Just purchased a qled tv. Video sharpness of live tv is poor with cox. Are there tv settings or cable box settings needed to improve the experience?
  • KevinM2's avatar
    KevinM2
    Hello, using the Contour remote, you are welcome to change the Video Output Resolution under Device Settings. In doing so, this adjusts the aspect ratio on your television:
    www.cox.com/.../managing-contour-2-device-settings.html
    Below are the different format resolution options. Not all formats are available on all TVs.
    1080p Wide - for 1080p HDTV monitor with widescreen 16:9 oblong shape
    1080i Wide - for 1080i HDTV monitor with widescreen 16:9 oblong shape
    720p Wide - for a 720p HDTV monitor with widescreen 16:9 oblong shape
    480p Wide - for a 480p TV monitor with widescreen 16:9 oblong shape
    480p Std - for a 480p standard TV monitor with standard 4:3 square shape
    480i Std - for a 480i standard TV monitor with standard 4:3 square shape
    For additional support, you may need to contact Samsung directly at 800-726-7864. -Kevin M. Cox Support Forum Moderator
