stinkfoot63's avatar
stinkfoot63
Contributor II
2 years ago
Cannot disable nomorobo
I suspect this feature is responsible for my two-part authentication calls being disconnected when trying to access accounts.  I go into phone tools and click it to shut off, but when I log back in it always is on.
Every other change I make is stored but this feature will not shut off.
    I'm curious if Nomorobo has ever worked for you.
    - On Cox, disable Simultaneous Ring
    - On Cox, remove your Nomorobo-assigned number
    - On Nomorobo, disable your Cox-assigned telephone number
    • stinkfoot63's avatar
      stinkfoot63
      Contributor II
      Actually disabling then reenabling "Nomorobo/Simultaneous Ring" (click it twice) opens a submenu where one is then able to disable "Nomorobo"- once saved the parent toggle (Nomorobo/Simultaneous Ring) reverts to "off".
      The interface is somewhat counterintuitive and can be a frustrating time waster because simply trying to toggle "Nomorobo/Simultaneous Ring" off does nothing apart from instigating discussions like this one.
      I believe the feature has prevented a good number of calls from ringing my phone but I suspect it has some unwanted effects on some needed automated calls.
