Why is my Nomorobo all of a sudden not working and no one is responding to me about this when I question it?
Perhaps something changed. Did you check the settings in your Cox and Nomo accounts?
I can relate with You on this, Mine never did start working from the time I set it up several months ago ???
According to Bruce, The Robo callers would generate a new phone number they were calling from every time, A NO Win Situation,. Good Luck.
57% of my calls are from unrecognized onetime numbers. 4% are unrecognized numbers calling again. Nomo is only good if you know what number to block.
Everyone swooned over Nomo but it's useless against spoofing.
Please try the following: Delete the Nomorobo number from the simultaneous ring list and then reactivate Nomorobo. This can be done by logging into Voice Tools, then click Settings / Simultaneous Ring/ Nomorobo / Simultaneous Ring and delete the Nomorobo phone number from the list of Simultaneous Ring Phone Numbers and click save. Then refresh and click on activate Nomorobo.
BrianCox Support Forum Moderator
