RBG
6 months agoNew Contributor
Audio is fine. Remote works with the TV and a soundbar. I've tried the codes that pop up when I go to the remote settings in the contour menu. The model is VFD32M-0807. Thanks.
WiderMouthOpen
6 months agoEsteemed Contributor III
Did you try 11758?
- RBG6 months agoNew Contributor
Yes, that's the default code that shows up when pairing the remote.
OK, I starting pairing again and found out that the code 11758 does work to pair the TV to turn on and off and control the TV volume, but when I pair the Insignia soundbar, the soundbar pairs but the TV pairing goes away. Any ideas on how to get around this?
- WiderMouthOpen6 months agoEsteemed Contributor III
No sorry. Maybe a moderator can help.
