mario92
3 years agoNew Contributor
Wall mount tv
I’m looking to mount my tv to the wall and put my receiver behind the tv so no wires or receivers are showing. My question is will the contour 2 remote work even if the receiver is not visible?
I’m planning on upgrading my receiver anyway to the coutoer 2 what type of remotes do those use?
If you're not having any problems now...don't go looking for 'em. Contour-2 is bloated with nonsense and easily errs. For the past week, after I press a button, it takes about a minute to process. I'm figuring lots of latency on Cox's TV distribution system. It's just silly.
