jwblue17's avatar
jwblue17
4 years ago
Television and cable box automatically turn on
It happens the same time in the morning around 10:00 AM but not every day.
Tried switching the HDMI port the cable box plugs into but same issue.  This happened with a previous Cox cable box as well.
Even if nobody knows the reason for this that ca be fixed would there be a way to prevent it from happening?
  • Hello, I recommend checking both the TV and cable box power on settings and see if that helps with this issue. -Allan, Cox Support Forums Moderator.
