jwburchell's avatar
jwburchell
Sound cuts out intermittently.
For approximately 3 weeks the sound on Cox TV cuts in and out intermittently for a brief second or two as if dialog was bleeped.  This does not happen if I switch input to antenna.  I know others have had similar problem.  What has been the solution, if any?
  • ChrisL's avatar
    ChrisL
    The first place I'd start is by doing some experimentation with the HDMI connection. Testing different cables or different ports on the TV would be a good start and see which way the problem goes.
    -Chris
