Corgi
8 years agoNew Contributor
I tried the channel up button, but box did not come on..However, found out if I pressed one of the number buttons, the box would turn on from power save and then turning on the TV with only the TV power button solved the problem. No more issues with the dreaded "no signal"! Thanks for your tip.
- JonathanJ8 years agoFormer ModeratorHi Corgi, Glad you were able to find a resolution please let us know if you have further issues. Jonathan J Cox Support Forums Moderator
