Marcovaldo's avatar
Marcovaldo
7 years ago
Power down by voice
I used to turn off my Contour box by pressing the "Listen" button on the remote and saying "Power down", at which point the option to do that would appear on screen. All of a sudden, this doesn't wor...
  • matts6887's avatar
    7 years ago
    Update again coz the power down by voice command is not working again!!! It was working prior to yesterday when there was a partial outage in my area which is the Phoenix metro area. Please make it work again as it’s a royal pain in the butt to have to do it the long way by going to settings then device preferences then power then power down. It’s so much simpler to do it with the voice command. Please find a permanent fix for this so that it will always work!!!
