I think the notes from WiderMouthOpen and Bruce are going to be helpful.
I'll observe that I have one television (networked) that periodically just gets completely out of synch and I've found the best approach for that specific device is to just power down, unplug, let it sit 30 seconds, plug it in, and power it back up. Since the power is a little awkward to get to, I just added a Kasa TP Link Smart Plug which integrates with my Google Home. This means I can just use the Google Assistant and say "Hey Google, Bar TV off" and "Hey Google, Bar TV on" to take care of the issue. I'm experimenting with a variety of mechanisms to improve automation and control, not because I need them now, but so I am in a good position down the road to stay in our home as long as possible. Those Smart Plugs are a handy way to deal with "legacy devices" that may need a power reset from time to time.
Good idea. I know someone that used a dumb plug(just had a rotating timer on it) to power down their modem and router every Sunday at 2AM. I know because I used to game with them if it had disconnected us mid-game once or twice.
- Olga3 years agoNew Contributor
Thanks - I need something simple to use for a senior citizen. One button for on / off. Hoping Cox has someone that understand the issue.
