cat509's avatar
cat509
contour remote problem
When I try to press any buttons on my contour remote they won't respond. Only when I talk in to the remote will the channel change etc.
  • @Cat50969, Please unplug the power from the cable box for 2 mins and then plug it all back up. Please let us know if that helps. -Allan, Cox Support Forums Moderator.
  • beardking's avatar
    beardking
    Get used to nothing but problems with their remote and the Contour system as well.  They are the absolute worst setup in the history of electronics.
  • bearone2's avatar
    bearone2
    Contributor III
    you can check battery charge in settings, almost easier to change batteries monthly.
    If unplugging, batteries and all else fails; swap it out.  Don't cost nuthin'.
