WiderMouthOpen
3 years agoEsteemed Contributor III
I have heard of some people getting the boxes to work wired/ethernet with their own router but YMMV. Some say you need the MoCA adapter inside the gateway for the Video over IP connection while others say you don't need MoCA since it doesn't use a coaxial connection.
- Darkatt3 years agoHonored Contributor
it MAY work with Ethernet, but I wouldn't place any hard currency on that.....
Either way I don't think that solution will work for OP since if they could run a ethernet wire over to the room then they could just run coaxial and use a normal box. I was just saying it for FYI.
