LambazNew Contributor5 years agoBoth of our wireless cable boxes went out at same time My hardwired box works fine and the internet is up and running. I reset everything, unplugged and plugged back in. Refreshed entire system including router. How can 2 boxes fail? Is this a router issue? A tech cannot come out for a week!
2 RepliesReplies sorted by Most LikedReplies have been turned off for this discussionJonathanJFormer Moderator5 years ago@Lambaz It's possible the wifi signal may not be reaching the boxes, also make sure the moca is enabled on the gateway, and both 2.4 and 5Ghz share the same SSID. Jonathan J Cox Moderator bearone2Contributor III5 years agocox or non cox router?
Recent DiscussionsForums Undergoing MaintenanceWhat was included in this Cox TV software update?Both Fanduel channels (Bally) are and have been choppy reception and audio for almost 2 monthsFYI - Once again, unable to perform Searches on Contour 1 DVRNo TV Service Again!
