Hey Bruce - Thanks for the reply.
Yes my box has those 3 settings. Using the "stereo" setting seems to last the longest - a few min - but then the audio gets out of sync.
There is no lip sync control. From Googling further, this appears to be somewhat of a common issue between Samsung TV"s and the Sonos Playbar...I'll keep digging as I doubt Cox support can do much, if anything.
Okay...now check the audio setting on your TV. You don't want either Contour or your TV to process any audio data. Just feed the raw audio to your Sonos.
- Marcust9995 years agoNew Contributor
Yep. I actually just set the TV to output just normal Stereo and it seems to be in sync. I'll keep and eye on it. Thanks!
I was thinking perhaps a "pass through" or Expert mode on your TV. 2-channel stereo is just 2 channels. Doesn't your Sonos support higher formats?
