tjharris
5 years agoNew Contributor II
This sounds to me like misconfigured dns server. Try rebooting the modem then reboot the pc. I am also assuming you didn’t clone the MAC address.
- stratmo5 years agoNew Contributor
I have rebooted both. And I haven’t cloned the MAC address, but I did use Ipconfig /all to find the address and I manually entered it into the ‘radio’ or whatever it’s called.
- tjharris5 years agoNew Contributor II
Huh. Radio? When? That doesn’t,t sound good. I would reset the modem. Your dns problems are likely in the modem not the lan.”radio would tend to mean WiFi which means you could have packets all over the place. I think I’ll let someone more knowledgeable help you.
Thanks. And you mean factory reset? Or power cycle?
