mkampe14
6 years agoNew Contributor
Hello,
I'm glad I am not the only one experiencing this problem with the new router. The WiFi is working on my iPhone and laptop fine, but my Vizio TV cannot connect to WiFi. My network isn't even listed as an option to connect on the TV. I tried calling Cox tech support, but they told me it is a TV issue. It worked fine with the old router, so I don't think it is a problem with the TV. Any input or help from Cox would be appreciated. **I did a factory reset on the TV, no luck. I have reset the modem multiple times with no luck either.**
Thanks, Mara
What make/model of Vizio TV?
- bearone26 years agoContributor III
fwiw, message on samsung tv, "no wi-fi, unable to connect to samsing for update".
i had to use the tv remote for change to wi-fi.
- MaryF6 years agoFormer ModeratorHi Mkampe14,
Are the two devices that are connected to the WiFi connected to the 5Ghz wifi network or 2.4Ghz WiFi network? If connected to the 5Ghz wifi network, it's possible that your TV may not be 5GHz compatible which could be why you're not seeing your wifi name on the list. We recommend you check your Wifi settings and ensure that the 2.4Ghz network is enabled.
Mary
