Initially I was interested in reviewing posts about WAN connection problems relating to my Cox Panoramic Technicolor modem dropping my connection several times a day. The problem isn't my cable plant, my electrical power or my software configuration, it's the modem. I can see the LEDs going from solid to blinking to off for no apparent reason. Even a hard reset several times a day doesn't help. Cox was out, updated my cable plant from Demarc to modem and replaced the modem. In reading other posts I know I'm not alone with this problem. There are no software tweaks available from Cox to address this and the online troubleshooting apps and logs are very basic.
I could be wrong but maybe it's this record heat causing these issues as I'm also losing connections just like you are.
