lsu1262's avatar
lsu1262
InkBird WiFi temp will not connect
I have an InkBird WiFi temperature monitor for my smoker. I upgraded to panoramic WiFi and the controller will not connect to my router. Any suggestions? It only works on 2.4 signal.
    What's the controller?  How does it work:  smoker > router > router > website...or is it a direct connect from controller to the smoker?  Is the controller on your home network?
    • lsu1262's avatar
      lsu1262
      WiFi direct connect to router only on 2.4 channel as per manufacturer.
  • bearone2's avatar
    bearone2
    Contributor III
    not everything will connect to pano wi-fi, 2.4 or 5
