jd284
6 years agoNew Contributor
Thanks guys. I ended up removing all connected lines and using a 2 way splitter as a coupler for now. the only line connected is the one to the wall connection at the new location. After 24 hrs of streaming, browsing, gaming etc the number of uncorrectables is much lower and i have not experienced a disconnect yet. I think i just need one of these to replace the splitter https://www.showmecables.com/f-type-female-to-f-type-female-adapter?gclid=EAIaIQobChMIw9eR9ZCj5AIVBJyzCh3RBgAkEAYYASABEgIXVvD_BwE
As Mouth noted, if you don't need the New Location outlet, don't connect it. You're only weakening your signal.
