- Tompot22New Contributor
Same, I upgraded to Panoramic CGM4331 modem, everything in the house connects except the Blink Sync Module.
I separated 2.4g and 5g with different SSID Names making sure no special characters in name.
i turned off 5g , change IP range of DHCP.
even tried turning off WEP-AES, nothing has worked.
I get a red light on Blink sync monitor when trying to connect.
if i look at connected devices in Router setup i see it, but Blink setup fails.
- JonathanJFormer Moderator@Sam90211
Are you using a different SSID (network name) if so make sure it is updated on the camera?
Cox Moderator
