Thank you for the suggestions, the Contour receiver that has the issue is a Samsung XG2v2 HD. The unit will display the Welcome screen followed by the "connecting you to your experience" screen, but then the screen goes blank. A failed video output makes sense, but doubt Cox will just swap the box without a service call. Should I try using the coax "cable out" to the TV in lieu of the HDMI cable, maybe the issue is with the HDMI driver/output? Thoughts?
No, they should. It is common practice. That is why they have boxes at the Cox store.
Sure, that is something good to try. You wouldn't want to keep it that way because it wouldn't be in HD but it is good troubleshooting.
Coaxial cable can support HD (HDoC); however, coaxial cable cannot support HDCP.
- WiderMouthOpen2 years agoEsteemed Contributor
The coaxial on the box does not output in HD AFAIK. See thread here where you even said so.
"You won't get HD via coax. You'll get HD via Component but it appears none of these units have Component."
...and beneath my post, I wrote "could" put out HD. Whether any of these boxes are engineered to output HD via its coax is one thing but coax can support HD.
- MikeD0072 years agoNew Contributor
Thanks so much for the information, much appreciated!
- 12 years agoPrincess_Grace
- 10 years agogshelly
- 7 years agosnoopy
- 10 years agostenochick
