AcousticDi
11 months agoNew Contributor
Simple Instructions for connecting Air Printer to Cox Panoramic Wifi.
Spent over 2 hours trying to get my Canon ip7200 Airprinter connected, including a call to Cox that told me there was no longer a WPS button and I needed to consult my printer manufacturer or manual. (What?) Ii tried this on a hunch, and it worked beautifully...
1 - Set your printer to connect to AirPrint (mine was to press the blue wifi button on the front for 3 seconds until it flashed).
2 - On the Back of Cox Pano modem, there is a white button near the top that has 2 arrows on it (you can hardly see them). This is the same as a WPS button. Press and hold for 2-3 seconds until the unit flashes a blue light on the front while it is connecting.
3 - After it turns white, it is connected and your printer blue light should be solid.
COX! Please put these instructions in the trifold you send out with the unit and make this info is readily available online. Maybe even educate your phone techs. There are people all over online looking for this SIMLE info!
