- KevinM2Former Moderator@dave in phoenix Hi Dave, was this a one-time occurrence? Your signal levels look extremely healthy, and I'm not detecting any packet loss at this time. Can you perform another speed test on a hard-wired connection and share the results for us, please? -Kevin M. Cox Support Forum Moderator
- davephxNew Contributor II
Thanks - I have been up about 3 days without rebooting and I just tested on speedtest.net and the site you recommended https://www.cox.com/residential/support/internet/speedtest.html
Both were very close 63Mbs down and 64Mbs. Upload is always the expected about 35Mbs since not on fiber. As indicated if the reboot will go back up to about 700Mbs range. This is hardwired ethernet to the router on high end chip etc PC. Have CM1000 DOCSS 3.1 modem and latest Orbi MAZE router.
For most of what I am doing really don't notice slowing speed unless it gets down to about 10Mbs - but nice to have close to the gigabit I am paying for.
Just for fun, I redid the PC connection direct to the modem. Detected but no internet access so rebooted modem. OK, still same 68.6Mbs down direct to the modem, bypassing Router (and Gigabit switch I have since so many connections to devices.) But that should eliminate any issue with router etc yet still slow DL. Ping 10ms which seems fine.
MB is ASUS PRIME Z370-A
I did some Googling and didn't find any reports similar to mine with the MB. Since it starts out at about 700 but deteriorates over time is weird :( and frustrating! MB is rated for gigabytesI have 32GB of fast memory about 48% in use - 37% of used is Chrome since I understand does a poor job of releasing. Only have four tabs open in Chrome.
Anything else I can check :(
- KevinM2Former Moderator@dave in phoenix Hi Dave, thank you for providing this information. Currently, a known network outage has been declared in your area, and the status of the outage can be tracked using our Cox Connect App, https://bit.ly/2w4fWWF. Until this outage is cleared, your services will continue to be sporadic throughout the evening. We apologize for the inconveniences this outage may cause. I am including an article which provides ways to achieve Gigablast Speeds, http://bit.ly/2KK3EP5. We recommend performing speed tests when the outage clears. -Kevin M. Cox Support Forum Moderator
