The best I can do is get this remote to work with volume and channel up/down. Its a bit useless
if you need to change the INPUT like HDMI for a game box, or the antenna input for a over the air antenna.
I still have to reach for the TV remote. Would anyone know if this remote can access other functions of a TV?
My TV is a Vizio E370VP
Thanks,
Ken
Hello, thank for the reply however the unlock feature freeing the remote from the cablebox allowing for channel entry
was the only thing that worked. I need the MENU, SETTINGS and the LEFT/RIGHT/UP/DOWN arrows to work
for the TV allowing me to change the settings in the TV as for example changing the HDMI input, switching to
the coax antenna input, etc.
