KenKK
Contributor
Hello, thank for the reply however the unlock feature freeing the remote from the cablebox allowing for channel entry
was the only thing that worked. I need the MENU, SETTINGS and the LEFT/RIGHT/UP/DOWN arrows to work
for the TV allowing me to change the settings in the TV as for example changing the HDMI input, switching to
the coax antenna input, etc.
Ken
CarolLM
6 years agoFormer Moderator
Hi KenKK, to make those changes you'll need to use the remote that came with your television or use the buttons on your television. -Thanks, Carol
- 4 years agoAlex_M
- 5 years agoJRD59
- 6 years agoOMAQman
- 12 years agoazcpl85711
