TV Caller ID not working. . .again
My TV Caller ID has not working since 1/29/19. I've rebooted the STB and confirmed that the feature is enabled with the remote. This happened earlier this month (1/9/19) and was told by Cox Support that the issue is due to the deactivation of the TV caller ID in the Cleveland market due to inbound/outbound call issues. Is Cox having this issue again?
  • Not only in Cleveland......in RI too, no call history available for 3 weeks!
  • Sometimes disabling and re-enabling TV Caller ID fixes it.  If disabling/re-enabling doesn't fix it, you could try combining it with another action.
    Disable for 5 minutes
    Disable for 1 hour
    Disable, turn off cable box, re-enable
    Disable, reboot cable box, re-enable
    I understand it sounds like BS but it's worked for me.
  • It is also not working in Southern California !
  • Caller ID is out in the Virginia Beach area also. Tried resetting the cable box, but it hasn't come back.
  • Hi Mamaluk,
    That issue does currently affect Cox Digital Telephone customers. I apologize for the inconvenience this means for you. We appreciate your patience while we work toward repairing the issue. A fix will be implemented as soon as possible.
    Erica
