WiderMouthOpen
Esteemed Contributor
Try swapping the box to a working outlet. If the problem follows the box, could be a bad box. Try swapping it out at a Cox store. If the problem happens with the other box on the first outlet, try replacing your splitter/amp. Also, what model boxes do you have? See here for a list or you can sign into you account and see that way.
WiderMouthOpen
2 years agoEsteemed Contributor
null Why the thumbs down? Do you have a better suggestion?
- 12 years agoPrincess_Grace
- 10 years agogshelly
- 7 years agosnoopy
- 10 years agostenochick
